Ends in 6 hours
We are trying to make the vanos work but I have not found much info on the correct way to connect to the fueltech. All the selenoid we have install in the past have 2 wires. The S54 has 3 (intake advanced, intake retard, 12v) same for the exhaust.
The engine is running good, intake and exhaust cam sensor are working. Vanos does not work.
This is some of the info I found looking the internet (Link ecu reference)
Pin 1 Inlet retard Aux 1
Pin 2 Ignition Switched +12V
Pin 3 Inlet advance Aux 2
Pin 4 Exhaust retard Aux 3
Pin 5 Ign Switched +12V
Pin 6 Exhaust advance Aux 4.
Text
