G4+ thunder Idle issue
Hey guys,
Any thoughts about attached pictures? So idle status remains - "decreas idle" while RPM Is well above threshold. ( Main Idle RMP at 90 degree C is 1000)
Can you attach the actual log file and a copy of the tune. Is it on 5.6.7 firmware?
Unfortunately I couldn't save log file. I did try different firmwares. 5.6.5. 5.6.7. Same
I can do new log later. Meanwhile I assume that problem can be because I am operating E-throttle without APS signal assigned. ( E-throttle table axis is spanned with custom voltage input) but at idle Close loop is still operating.
