Gear Shift load Cell question
Hello friends
Can anyone comment on this load sensor or alternative, more cost effective, sensors:
This one seems a bit costly at 400+ USD.
https://www.kasensors.com/sites/default/files/downloads/GSS%20datasheet.08.22.pdf
Thanks in advance
D
I use those on several cars, including my wife's race car. If you're getting them for $400 you've got a good source.
Hi David
Thank you for your Input on this.
D
Hi again,
What is the preferred mounting method in your opinion? ie. embedded within the gear knob (angular movement) vs integrated (push / pull) or other proven techniques ?
Your help is highly appreciated.
TIA
D
"The Load Cells are generally installed into the actuator rod or cable on sequentialgearboxes."
It's a longitudinal design strain gauge.
Thank you Gord.
Here is how that sensor is installed onto the end of our shift cable.
GSS Installation
Hello David
Thank you for the photograph.
