Guide discussion from experts success stories to start tuning
Hello Experts,
This post might be covered partially in another threads but i cannot find an answer to all of my questions.
I'm starting to learn the tuning that's why I enrolled in HPA VIP to learn in a professional way .
1- Can you please guide me the best sequence to follow to go from Zero to Master the tuning?
2- I've LinkECU Monsoon G4+ with 2JZ-GTE engine and HP with LS1 to practice on it step by step from scratch (Even startup file to start the engine)
3- I've theoretical background about EFI, AFR, Timing, ... etc.
Appreciate your help and suggestions.
if you have all the theory as you say and software and engines available then the best way is to just start. its like riding a bike. the only way to learn is to start. you will mess up along the way, you will fall off, you will blow things up. but its all learning experiences. you will not learn unless you make mistakes. good luck dude
Thanks James but still i need to have some info from the courses , i know the theory but there are some calculation like fuel table, timing, AFR with RPM/MAP i must know to start
oh right sorry i miss understood. i just assumed you had watched the tutorials on here? thats the best place to start
