Haltech E6X trigger setup
Hi guys does anyone have a base map for a haltech E6X running a 1jzgte non vvti or perhaps are able to help me with the tirgger setup? from what i understand it must be on multi tooth but from there I'm not sure where to go.
Should be multiooth 24 and 1
triggers are reluctor
both pick up on the falling edge.
start with a 60 degree trigger angle and work your way from there with a timing light
Thanks will give it a try
