haltech elite 4age startup up
have a 4age 16v distributer trigger options have the 24 tooth 1 home the distributor is not that
how could i change it
also i am new to the haltech how do i change to different size injectors didnt see the options
I've attached a picture of the injector option in the drop down menu at the side of the ESP software, set up the dead time and flow and you should be good to go.
What trigger pattern have you got? choosing one of the other distributors might suit, the beams 3sge engine uses 36-2
now got back to the tuning
haltech elite 750 4age 4-1 trigger in the distributor i am not seeing that option
it is also using the standard ignitor box and coil
what options could i use that would be compatible with that trigger pattern
or if anyone have
start up map that uses this thank you
i installed a generic multitooth setup single home
changed the # of teeth to 4 but the missing tooth setup should i put 1 because zero is not an option ?
