haltech elite trigger setup
Setting up 4AGE with haltech elite attach file shows the distributor internal trigger wheel and home it is 4-1 four trigger teeth 1 home
i have the elite universal basic harness . four wire out of the distributer red/green/yellow/white
below is how the wiring is coneected
ecu pin 32 cam(+) - yellow distributor wire
pin 31 crank (+) - white
pin 11 signal GND - red/green
this wiring was working because the car was starting , the ecu was locked and we could not get hold of the tuner a new map needed to be created . could you more experience guys help me out with the trigger and fuel setup. it is a single coil and oem ignitior
SEE PIC ATTACHED
thank you
