Having problem syncing
My setup was 4 cylinder 4 stroke no crank sensor but have only cam sensor(which is ref signal for m84 ref/sync mode 6 with 12-1 trigger pattern on cam) crank teeth No. 6(for correcting the RPM) but it wont sync.what do i missed here?
Sawadee krub K. Satawat
What ECU ?
What engine exactly?
Regardless, Install a reliable crank signal to begin with. Synchronizing means: To align the camshaft position to the crankshaft position.
I have not yet heard of a camshaft signal to be synchroninized to its own source. Even If I may lack information in this particular case, it is generally best practice to trigger crankshaft-position directly off the crankshaft.
