Hayabusa Gen2 AFR target table.. Your opinion ?
Please take a look at my afr target for this Hayabusa Generation 2 as a starting point. Dyno sessions follow later. Any comment will be greatly appreciated.
Thanks guys
Fuel 95 Gasoline
Altitude Sea level
Temp 30 - 35 deg C
Mod: Yoshimura full race exhaust 4-2-1, KN Air cleaner
PS: the zeroes are in place to disable the Autotune (due to exhaust flow reversions and where it is not needed) in the respective cells.
I'd say that you've got a safe and sensible starting point. If you're interested at all in economy then you could lean out the midrange targets towards 14.7:1, particularly at lower rpm. You may also find that the engine responds by targeting slightly leaner at WOT, particularly at high rpm. The last hyabusa engine I tuned I ended up with a WOT AFR around 13.4 tapering to 13.2. Your starting point is safe though so I'd just test and see how it responds.
I agree with Andre. I own 2 hayabusa's. One is an all out drag bike and the other is set up for drag and street. I tune both of them plus all the ones that come thru our shop. Your starting point is perfect for a starting tune on a stock motor. It should need less fuel in the end.
Thank you both for taking the time to review and comment my table !
Be shure to post your results. ECU editor will give you a lot more tuning capability than a power commander but it takes a lot longer and you can't make changes in real time.
