Ends in 5 hours, 59 mins and 59 secs
I just started tuning with hp tuners and i was trying to use the copy and paste function . the VCM scanner being set up in air grams and the editor in in kpa does not allow to copy and paste . if any one can help me out it would greatly be appreciated. TIA
What are you trying to copy paste? Fuel table? Is it speed density?
Have you set up a histogram you're wanting to paste over?
Sounds to me like you're logging a different parameter from the editor. I.E Air mass vs manifold pressure.
You can change the parameter in editor by right clicking on the table and selecting units. Although I don't think you have the option to change from KPA to g/s as these are 2 different measurements (pressure vs mass)
You can also change the parameter you're are logging in the Scanner by right clicking on the histogram or channels and selecting graphs layout or add channel.
If you can send through a bit more info or screen shots of what you're wanting to copy paste I am happy to help
Text
