IAT Sensor Data
Hello,
i am searching for the temperature / resistance values (ntc curve) for the following intake air temperature sensor:
Hella 6PT009109-141 (BMW 11 61 3 449 116)
I have tried searching but haven't found anything. If all else fails I suggest you go with a Bosch sensor. The data is readily available.
thank you for your help. I have found the data in the PC Link help folder
