Hello, I have a nice idle target curve, but for some reason, when the target should be 1000 RPM (according to the target table I have built), the MegaSquirt displays 1500 RPM on the idle target gauge. Then the actual idle RPM is around 1500 obviously.
Any idea why mega squirt chooses a higher target RPM than the target table I gave it?
Target curve attached. Fans starts a 97deg, I had to up the idle target for the car not to stall.
Thanks a lot and have a wonderful day.
The A/C Idle Up system can increase the idle over the table value. Perhaps it's enabled but not detecting the A/C state correctly. I would look at every single window / table under the Startup/Idle menu in Tuner Studio for anything that can affect Idle, make sure you read the help and understand every value.
Ok, I guess it was the A/C indeed despite the fact that I don't have A/C lol thanks a again :)
Have a wonderful day.
