Ignition timing vs spooling turbo
How does ignition timing affect how a turbo spools up?
I road tuned backed off 3 degree timing from -4 vac to 8psi turbo seems to spool up much quicker
Tuning gear: Knock box
Aem Wideband
Vehicle: Toyota Mr2
Setup: Borg warner s366 turbo
HKS 264 cams
Wiseco 9:1 pistons
Haltech ps1000
max boost 24psi
Hp: unknown
The answer is that yes igniton timing can effect the way the turbo spools. What we are trying to achieve to spool the turbo is maximise exhaust mass flow as well as exhaust gas temperature. While retarding the timing a little can increase the exhaust gas temperature, we will also find that as we move away from MBT timing, the engine naturally will start to lose torque.
My personal experience is that the best way to optimise turbo spool up is to optimise the ignition timing to MBT at each point in the rpm/load range during the spool period. You can find that using a slightly leaner AFR during this same spool period can have a slight positive effect on boost response due to the increased EGT.
