Injector dead time table Haltech elite 2500
Hi all, I have just purchased some x spurt 1500cc injectors for a turbo barra, still learning how to tune so bear with me..
Below is the current dead time table and also the sheet that come with the new injectors
Question is do i need to add another axis and create the table to be exactly the same as the sheet that came with the injectors?
Cheers
No, just use the column that has the differential fuel pressure you are running (ie, what you've set your fuel pressure regulator with the engine stopped, or the manifold pressure tap disconnected).
Ok thanks, is it an advantage in any way to add the different pressures and times Seeing as though I have a fuel pressure input into the ECU?
