Injector Flow Rate and Deadtime.
Hello! Can anyone, please, help me figure out the correct flow rate and deadtime for my Bosch 0280156372 injectors? I've searched the web and I find different values for flow everywere I look and as far as dead time values I didn't find anything.
Found some charts where they're rated at 150cc/min, found them for sale on different online shops with different specs every place, some rate them at 138.9 g/min some at 116.5 g/min, 150 g/min, I even found some 162 cc/min or 15.4 lb/hr.
Also, does N-Heptane have the same flow rate as Gasoline? Because all the flow rates that I found are done using N-Heptane as test fluid.
As you can guess, I'm very confused. Please help!
