K series ignition after adjusting cam gears
Been watching the Hondata dc5 tuning session which is awesome. Curious if you plan to adjust the gears with adjustable cam gears do you have to adjust the cam sensor pickups as well to where it is supposed to be at tdc?
Is ignition solely dependent by crank shaft speed sensor or does it look at the cam sensors as well?
