knock detector options?
Hi guys,
I want to buy a knock detector, which do you think is the best value for money?
I would appreciate recommendations.
greetings and thanks
I used the Link Knock Block, loved that it was portable, easy to setup (there's basically 1 knob on it lol). Audio was very clear. I switched to the Plex Monitor v2, which has more functionality, but takes more time to setup and it's pretty pricey. The main reason why I did the switch is that I wanted the audio filters.
Finally, there's a lot of good review about the Tuner Nerd, but I have no experience with it.
There's some webinar/article I think about knock detection on HPA, you should take a look at it!
Hope it helps,
Frank
I have finally bought knock monitor pro v3, I will let you know how it goes.
Cheers
