Knock Log "Flatlining" ... Link G4+ Thunder ECU
This has been an issue for a little while, my last attempt to fix was to run new shielded cable from the knock sensors to the ECU .... no improvement. Any ideas as to what is going on??
Attached are my PCL and Log files.
Would a "dodgy" TP Sensor cause this? As you can the TP is way above the low lockout setting.
https://drive.google.com/drive/folders/1o0ZSDnnPyHH7yaBNT5WScKzbbdb2Lv1a
It has been confirmed by "Link" that there is a fault with either the Hardware, Firmware or Software, we won't know which until they have a look at the ecu. This will happen when the current "lock down" situation is over.
