knock threshold
Hi Andre
what are the safety knock threshold valve while I am tuning an engine. if just because I want to know if I can set my own threshold
valve or this valve already exit and I have to use them, what are this valve or there are different for any particular engine.
best regard
There isn't a single knock threshold that you can apply to every engine and/or ECU. It will depend to a large degree on the signal level from the knock sensor as well as how effective the signal processing is. Have a look at the webinar we did on knock control using the Motec M1. This discusses how to establish a knock threshold.
https://www.hpacademy.com/previous-webinars/motec-m1-knock-control-example/
