Link G4+ Fury E Throttle Config Issue
Hi, Could i please ask the following as its slowly driving me mad. I have a Toyota Celica Time Attack car ST205 i am running the Link Fury ECU. My problem is I'm try to configure the e throttle but cannot get past the set up stage. The pedal position sensor is calibrated in both sub and main. The throttle position sensor is calibrated in both sub and main when the e throttle is off, but when the e throttle is switched on it can not calibrate which follows with error "error cannot reach target 98%". What does this even mean? Am I doing something wrong?
Any ideas gratefully received.
Attach the tune and a log of it running the TP cal procedure.
