Link g4 + traction control
Hello Andre I would like to get more information how the traction control mode work on the link ecu and how to set it up.I have seen some launch control webinar .but traction control is alot more advance.and I really want to start try it out and testing on a customer Fwd car.so far the car been setup with the front vss at the tranny and also boost by gear been working gr8.i was able to install a rear vss also with a 24tooth abs ring with a hall sensor and it's been calibrate on the road that front and rear wheels are reading same kmh or mph.is there anything else need to be at or configure for traction control.car been running a Link g4 storm + ecu. Or you guys are going to have a webinar soon on traction control
