Link G4+ with AEM CD5 DASH
I don’t know how to set the aem cd5 dash to work with link fury ecu. Can someone please guide me through the process. Thank you in advance.
AEM has very good set up instructions that should be installed on your PC with the dash software, also a preconfigered Link dash config is supplied. Have a look on your hard drive in the following location: \Docs\AEM\DashDesign\CAN\Link_G4+.pdf. You will also find the dash config in that same folder.
