Load Scaler on a Apexi Power FC?
Hello,
I have a RX-7 that I am tuning. My question is What load scaler measurement are they using? It starts at 1000-24,000.
Hi Mate,
Are you referring to the load multiplier? I think Apexi called it load scaler...... is the number 1.000?
If so, this adjusts the fuel map scaling for large injectors to maintain resolution in the tune.
Hello,
I attached a picture of the chart. The top of the chart shows the RPM measurements and the side column to the left is the load. What measurement/value is "load" represented in?
Its in absolute bar x 1000 so
10000 is 0 Psi
20000 is 14.3 psi
24000 is 20 psi
Thanks Nz3andre for the help!
