Looking for some help with Haltech NSP
So I've been working on this car for a while now, and I'm having a some weird issue with the engine breaking up through the RPM. It sounds somewhat like a 2 step/launch control is turned on, but it's not. Like maybe something with the ignition isn't right?
Car is a k20z1 with cams, big intake, PTE6266, ID2000's, WB450 pump (wired to 40amp off alternator). AEM wideband, Haltech Elite 1500
I've made a new map from scratch to see if anything was over looked or changed without me knowing. Still same issue
If anyone can maybe take a peek at this config and data log, maybe someone would be able to help me see what I'm doing wrong? Thank you for any input or guidance.
-Colten
What, if anything, have you done to the ignition side?
Have you tried closing the 'plug gap to 20 thou' to see it that made a difference?
