LS swap 1994 OBS Chevy tuning advice
I'm 15, doing an LS swap 1994 OBS Chevy. Do you know what OBD 2 link tool to use? I'm planning on using Tuner Pro, PCM Hammer, and/or Universal Tuner; or is there any other tuning program I should use to reflash the stock PCM/ECU? I’m new to this and don't know much about what I have to do or need.
Info on the Engine, it’s a 5.3L LM7 from a 2004 EXT Trailblazer with an aftermarket cam (I don’t know the information on the cam as of this moment) using the stock PCM/ECU with the NV4500 manual transmission from the 1994 OBS.
Any information for a tune? Everything is stock engine-wise apart from the cam. If any other information is needed let me know
