M4 and M400
Hi Guys ,
Having an issue with Alcatek Ecu on a GC8 V3 V4 running really rich, cant seem to log in as it requires a tuner file to access it despite having the dongle. Tried getting hold of Alcatek no response from there end.
I got managed to get hold of a Motec M4 and M400 need a start of point; a base map would be great if someone might have one the stock ecu is a 6S (3 Yellow Socket).
Thanks.
Hi AMK,
This is a early M800 OEM file that should work as a start point for you.
