MazdaEdit O2 sensor B1S1
Hello, I am getting my 2013 Mazda Verisa (1.5L ZY-VE engine) tuned using MazdaEdit. Can anyone who is familiar with the software tell me what do these readings mean for my O2 sensor B1S1? As you can see in the photo/file attached, the value in the middle column is highlighted in red which usually means something bad.
Also, when my wideband gauge begins to read AFR values greater than 14.84 or so (a.k.a leaner than stoich) the value in that middle column gets highlighted in red.
Lastly, I will say I am not getting any CEL codes but before I got the tune and ran on larger injectors with the OEM tune, I did occasionally get a P0133 code. However, that hasn't happened in a while.
Thanks in advance for your response.
