MG1CP007 - Optimum Engine Torque
Hi Guys,
Embarking on a bit of tuning with the Bosch MG1CP007 and I have a few questions about how Optimum Engine Torque tables work in this ECU,
There is one 14 X 16 table under torque request (image attached)
There are also quite a few 8 x 8 tables in the torque monitoring section all identical (image attached)
I understand the axis and that the Z axis is a percentage, but what I don't fully understand is their relationship with other tables and how they should be adjusted for stage tunes. (I'm assuming a DTC is not adjusted correctly along with Torque request tables).
Thank you
So from what I can gather is there is an inverse relationship with Torque Request tables and Torque Monitoring Tables (Optimum Torque).
Any pointers?
