Mini R53 ECU Master Black PnP Oil temp./press. implementation
Hello everyone,
I would like to integrate an oil temperature sensor and an oil pressure sensor into my ECU Master Black PnP Mini R53 ECU. Since I no longer have air conditioning, I could use the input for the oil pressure sensor there. However, I’m not sure where to connect the oil temperature sensor.
Does anyone know if there is a compatible gauge available for the Bosch 0 261 230 482 sensor?
Thank you very much!
