Motec M130— plex 120 pro Dash
Hi advisors
i am about to run a Motec M130 on my Hayabusa powered landspeed bike , i will be using a Plex 120 pro dash , any advice on the CAN connection/ protocols. would be appreciated
cheers
harky
I suspect the Plex will support the standard M1 Protocol. MoTeC support can send you a .DBC file if the Plex Dash allows that to be used for CAN setup.
