MPVI2 Wideband Pro Feature
Hi i have the MPVI2, i purchased innovate Lm2 thinking i could get setup in VCM scanner but no luck spent hours on it even bought the
RS232 cable still nothing, so i'm after another wideband,
What widebands would people recommend thru the CAN Bus Network as i assume that a wideabnd that can transmit on The CAN Bus would be the most
accurate correct me if i'm wrong.
Thanks in advance
Hi Simon, hopefully this isn't too late for you but we recently ran a webinar covering this setup - https://www.hpacademy.com/previous-webinars/219-getting-wideband-afr-data-into-vcm-scanner/
Alternatively we also have a new AEM CAN-wideband to test that is compatible with the HP Tuners software - https://www.aemelectronics.com/articles/x-series-aemnet-can-bus-digital-gauge-available-now
Please if you can help I would appreciate it.
I tried everything from webinar 219. I can not get it to work. I need the function inputs and I have no idea where to start. I tried the formula you used for anolog inputs but nothing. Not your exact numbers.
please let me know.
Alsdriftshop@gmail.com
i tried posting pictures but it won’t let me.
I have everything you have
