New Plex Knock Monitor SW and FW released
Hi Guys,
For those of you that have the Plex Knock Monitor V2, Plex have released a new version of the PC software and firmware for the device itself. Both versions are now at revision v0.67, and it appears to carry many bugfixes, improvements and new features.
Here are the release notes:-
8-Dec-2017
FIRMWARE v0.67
NEW: menu 8.4 to enable automatic start directly in monitor screen for in car applications
NEW: options for fixed 0V and 5V outputs added to analog outputs for calibration and test purposes
IMPROVED: better digital filtering for the RPM signal when trigger mode > 2
IMPROVED: additional error indicator for the can bus in menu 4.5
FIXED: when the USB cable was disconnected the device would freeze
FIXED: the Knocking Cylinder analog output now indicates the actual cylinder instead of the cylinder position in the firing order
FIXED: the can bus messages per cylinder level and count data now represent the data from the cylinder number instead of the cylinder position in the firing order
FIXED: Analog Output2 would mirror the Analog Output1 value
SOFTWARE v0.67
NEW: options for fixed 0V or 5V output added to analog outputs for calibration and test purposes
IMPROVED: drop down selection menus when editing the configuration now have the current value preselected
IMPROVED: drop down selection menus when editing the configuration now appear with the correct color theme
IMPROVED: after writing a configuration the device is commanded to reload it from memory so that a restart is not required
IMPROVED: the cylinder number buttons in the realtime screen now display the correct cylinder numbers according to the firing order
FIXED: error in displaying and sending the Analog Output 1/2 settings
FIXED: when changing a preset name to a shorter one characters beyond the new name length would be copied from the previous name
FIXED: after writing a configuration the device would not remember the selected preset for the next start up
Thanks for letting us know Matt!
Good to know, Thanks Matt
CLAIM YOUR 10% TRADE DISCOUNT
Our standard trade discount (10%) is provided to professional tuners, engine builders, racing engineersand racers (requires proof of profession) and to students of the HP Academy (requires proof of membership).
Firmware and Software versions 0.70 have been released by Plex. This fixes a few bugs in the CAN setup that I reported to Plex - they fixed it very quickly and I am quite impressed with the turnaround!
8-Feb-2018
Software v0.70
FIXED: The CAN TX ID was not displayed in hex as the label indicated
FIXED: The CAN TX ID value would revert to the previous value when another configuration setting was changed
FIXED: When disconnecting the USB cable during realtime data transfer, the software would freeze
Firmware v0.70
IMPROVED: in menu 4.6 acceleration has been added to the CAN Id value change
FIXED: in menu 4.6 the can bus transmit id was not displayed correctly
FIXED: the yellow and red leds would still be activated event if the level and warning threshold
FIXED: in menu 4.5 the trigger input was not activated
I reported some of those same CAN display bugs! Glad to see them fixed.
Their support is awesome! I'd say quite a few people came across those bugs as they were slightly annoying!
