New to LFX Tuning & Need Guidance
hi guys
so i got this car its a 2017 VF Series 2 SV6 and the car has had work done with cam upgrade OTR etc
it was also tuned by a reputable shop in Melbourne i am currently trying to work out how to get the lumpy 6 idle back as the previous owner didn't want it so had the shop remove it and i have never played with a LFX before only a LS
i also have another issue with the car no matter what i change idle wise the car continuously sits at a idle of 1000rpm
when in first gear the car will occasionally stall as if the rpm in first is not enough to keep it going
while driving also you can kind of feel hesitation in it when at WOT
i also noticed that the High octane table has also been copied down to the low octane table and was under the assumption that this was a thing not to do
i don't expect someone to come in and give me all the answers but kind of guide me into fixing this myself so i may be able to understand how this motor works a little bit better
i will attach the tune file i grabbed from the car but i do not currently have any log files for it unfortunately as i haven't really been out driving due to health issues
thank you look forward to hearing thoughts
nobody?
i have fixed the VVE table as it was really bad i also fixed the maf as well just stuck on working out the lumpy idle for the V6
i also managed to fix the stalling in first gear along with the idle being stuck at 1k rpm which was weird apparently changing reverse in the table is what controls the LFX idle in hp tuners haha
