NTC Termisyor voltage spreadsheet
Does anyone here have a spreadsheet to calculate NTC termistor voltage output depending on ecu suplied voltage and internal pullup ?
Thank.you
G'day Claudiu.
Threw this together: https://docs.google.com/spreadsheets/d/1AKuO6i5UpiKxylZiY5zdlH2w74y0L-xtcYI9N8XRSSQ/edit?usp=sharing
The sample thermistor resistances I have there are from the Bosch 026 Motorsport coolant temp sensor datasheet. You wont be able to edit it directly, but you should be able to make a copy of it for yourself, that you can then edit to add in the resistance values for your particular sensor :-)
Zac, thanks for that, really handy.
Thank you!!!
