Pairing injectors to a single ECU output, flow rate doubled?
I need some clarification on this issue:
Injector flow rate entered in ECU setting is usually the flow rate of each injector. But, when pairing injectors to single ECU output, should the flow rate entered in ECU setting be doubled?
Assuming the ECU is able to properly drive both injectors then yes, you would double the injector flow rate.
