PECTEL SQ6M problem Cosworth engine wont start
i have single seater running a Cosworth V8 engine with Pectel ECU and my engine is not starting . Looks like we can't get fuel flown from the injectors .
we don't know how we can find which sensors is not reading properly using the PI TOOL BOX Software . The car seems to have ignition system working properly , good RPM , fuel pressure on the pump and on the FRP and eletricity either including using a Jump start.
all this problem happened after we start messing with a Shiftech cluch control unit box that went bad and we need to open the Bell house to change a clutch Bearing servo seal was bad .
anyone really good on ECU can provide a service througth a video call live and connect to my ECU using a Team viewer ? Iam based in Miami FL
