plug and play stand alone for mitsubishi evo x
Hey Andre/fellow tuners,
I am looking for a direct plug and play stand alone ecu for a JDM evo X gsr.
Any recommendations from you guys on brands that offer a good package? So far I've seen motec and gems.
Anyone has any more insight?
Chris
Hi Chris here you can find direct plug and play for evo x http://www.gems.co.uk/
HIGH PERFORMANCE PLUG N PLAY ECU FOR THE MITSUBISHI EVO
The GEMS Mitsubishi EVO Engine ECU is a highly capable and fully customisable
engine implant built with competition in mind. With full anti-lag, launch
control, MIVEC and much more, the EVO ECU has got the technology needed
to take your EVO to a higher level.
The GEMS Mitsubishi EVO ECU’s are being extensively used in rallying across the world
and have proven themselves time and again. These are fully pin-to-pin compatible with
the Mitsubishi EVO standard looms, and bolt directly into the standard case.
evo10 side image
Features
Fits into EVO standard case and loom
Comprehensive anti-lag system
Launch control
Internal logging facility
Support for development sensors i.e. Wide band lambda and EGT
Wideband Lambda (EVO X)
Customizable MIVEC
Logging of serial and CAN data
Lambda control and auto mapping
Knock control
Boost control
Idle speed control
Gear correction
Individual cylinder control
Re-flashable firmware
Specifications
Comms: serial and CAN (EVO X - USB)
Twin CAN (EVO X)
All standard outputs plus 4 extra
All standard inputs plus 3 extra
512KB logging memory (EVO X - 8MB)
User configurable I/O
Single piece PCB
Available for Mitsubishi EVO versions: 1 to 10
Related Links
EVO Plug n Play Infosheet [PDF, 390k]
EVO ACD - EVO diff controller
GWv4 - GEMS engine calibration software
