power fc help
Hi lads I can't get map tracer working on my fc data logger or may I'm doing sum tin wrong had it working few times . Maby I'm doing some ting wrong. Or is there any other way getting live data
The tracer only works when datalogging is active. Try pressing F1, right click on the map and switch on the trail
Have done it many of times still no joy chris
It just highlights the first box. I've also noticed when I ad map watch boost , rpm it reads zero as it ain't picking up data
Is the datalogging working? It sounds like you.could have a duff sensor
Everton else seems ok. How wud I no chris
Check the values in the monitoring screen see if they're matching what's expected
Got it! Small vacume pipe uder inlet cracked and wusnt getting boost reading put it on clicked f1 then trace and boom worked thanks a lot for ur help anyway chris
No worries, that's what we're here for.
