RB25DET PRP TRIGGER
hello everyone, I just purchased the PRP crank trigger 12 teeth only for my rb25det and plan on using the stock cas fitted with an aem 24&1 for the home signal, my question is do I have to remove 1 tooth from the crank gear? I've read that I could be beneficial but want to know a little more before I install the kit on the engine... Thanks
I'd leave the crank trigger as is.
Semi related, I've had better success with CAS replacement vs. sticking that disc in it, but hopefully it will work well for you.
