rb26 lambda live stuck at 1.00
I have started a freshly built rb26 today for the first time thanks to the standalone course
the engine is plugged to emtron kv8
immediately after I started the engine I have noticed lambda live is stuck at 1.00 value and even after engine heated up nothing happened
could this problem be a software adjustment or it can be related to the sensor itself?
also I should mention I am using the old sensor and the engine had oil burning problem before the build.
Hello can you post your tune file and a log for us to look at we should be able to help from there?
Regards Ross
Was the sensor with this ECU working before the rebuild. If not, I would confirm the wiring and ECU configuration first.
what is the best way to upload the tune ? I'm trying to upload the file but upload sites don't accept ecf files.
well I can't confirm if it was working before the build but the wiring is good
hope this link works:
https://easyupload.io/0ty8vf
Any help?
