Rich AFR in low rpm/load areas - GT86 supercharged
I am desperately hunting for AFR in low rpm load areas. Unless the closed loop tables are set around 14.5 and engine is in closedloop mode, it is targeting at 13.6 - 13.8 in such areas. I can not determine where is the problem. The car has bigger PI DW450cc, which are dialed in somehow.
Thx for advices :)
