Setting up exhaust mass flow evo ix with a moyec m150
#hi there any pointers setting up this table some base settings to start from
Evo ix 2.4 running a 3586hta
any help would be greatly appreciated
What you do is hold the engine at one of the mass-flow rate breakpoints, then make a step change in the Fuel Mixture Main, and pause the time graph then determine the time required for the measured lambda to match the Fuel Mixture Aim. Repeat for different mass flow rates.
