Setting up Sensors?
While I'm sure that many people understand how to do this but, it would nice to have a webinar or course that shows how to set up different types of sensors on the M1 tune and Displays. Showing examples of pressure gauges, temperature gauges, speed sensors -hall effect/magnetic. The understanding and the definitions of the different parameters of sensors and their associated drop down lists. How to recognize and solve set up problems. How to obtain or test for operational parameters - throttle movement, temperature range voltages etc, Hall timing, speed tire speed, etc. Wiring - What , when and how to use pull up resistors & wiring shielding. Positioning of sensors -heat soak, radio interference and other problems.
Thanks-
Jack
Merci beaucoup! Didn't see that one.
