Share sensors
Was curious as to if there will be any problem sharing the sensors supplied with my defi gage to my link fury. Temps ,pressures speed ext?
Good day,
It is not recommended to share sensor to another device. You would create a voltage divider and depending on the impedance of both your device (gauge), the reading of both could be wrong.
The proper way to do that is use a 0-5v output from the Defi unit (if there is one) to an input of your Link Fury.
Frank
Awesome thanks so much
Temps and pressures can be shared fine. The speed will depend on what type of signal it is (AC or square wave). For the temp you will either need to connect to AN Temp 1 or 2 (as you will need to turn the pull-up off), or connect to a AN Volt channel instead.
