Smallest possible injectors (physical size) 400 - 500 cc range ?
Hello friends
I am searching for physically small dimensioned injectors (400 - 500 cc flow) for a stealth EFI conversion of a INDY V8 motor.
Can anyone recommend where to look?
Thanks in advance,
Dom
Thank you Gord. Very useful link indeed.
Just had a thought - because of the packaging constraints, would motorcycle injectors be physically smaller?
I would assume the very high end motorsport ones, used in applications like F1, would also be relatively small, but most of that stuff is $$$$!
Hi Gord, Motorbike injectors have also crossed my mind, will dwelve deeper into that.
Thx
There isn't a lot of forward development on port injectors in the OEM world, all of the development is towards DI and EV. Most high level Motorsports engine will use DI now.
