Subaru Ej257 base map for vipec i88.
Hi.
I've searched around but cant seem to find a working map for the vipec i88.
Base maps that come with the software are different and some outputs are missing.
I need a working base map so I can just start the car..
I have Id1000s .. so help with fuel scaling would be great as well.
Questions like tooth count on Trigger 1(crank sensor) ?
Is it 24 or does that need to be changed. (I'd compare it the base map but that option is not there)
Thanks
Remski
OK.. Looks like i figured it out..
Some might find it useful...
If you click on Trigger setup -> trigger mode, there is an option for Subaru EJ25 AVCS.
