Tunerstudio - dropbear - cbr1100xx
Hi,
im setting up a speeduino dropbear on a bike and have been through its triggering . It uses tunerstudio. ( ecu has inbuilt vr conditioner )
I can’t mod the triggers as they are inside the casings . I could break teeth off the cam pickup but would prefer not too.
any thoughts on if this is achievable without modding the cam trigger to only be one tooth for the reset ?
The goal is to run sequential fuel, wasted spark with Bosch dual igniter triggering the factory Cdi’s.
can anyone provide the correct base settings for tunerstudio ?
Thanks
jason
We’ll still no luck .
12 tooth crank with vr
1 tooth cam now with vr ( 105btdc)
timing is all over the place , sometimes none , sometimes only sparks as you turn key off . Shielded wires for crank and cam.
