Ends in 6 hours
hi greetings,,,, can i have some assistance im using a aem x series wideband output to the haltech elite 1000 but the gauge value and the value on the ecu arent 100% accurate how can i adjust it to get it as close as possible?
Hello, generally you will need to make sure the ECU and the AEM wideband are seeing the same supply voltage and earth points are close to each other any offset between the two will alter what the ECU is reading,
thanks for the feedback your correct
Text
