Variable cam timing calibration / needing guidance
Hi friends
Although I am familiar with the procedure of calibrating on/off variable camshaft timing, I do struggle with continuisly cam adjustment with 4 (V8) cams.
Can you recommend a HPA course, or share insight of what you deem best practice?
This motor is sitting on a eddy current engine dyno right now, MoTec M150.
Thank you all in advance.
Dom
Thank you David.
