Volute Water Meth
When doing a volute water meth set up would you only use the nozzles on the compressor or would you also use in injector prior/after tb ? Opinion on volute+direct port ? I am considering this set up with having an injector on the compressor and then direct port
TIA
Pre-turbo if you are at choke flow on the turbo, post intercooler if there is plenty left in the turbo.
